i have a pulley in pro e
which i imported as a step file in solidworks
the pulley has 25mm diameter(eg)
but when i create drawing of it in solidworks , it comes as 1234.345 mm
That means you've made mistake in pro/e itself. If still you had pro/e part > Open the part > Goto "File" > "Properties" > Under "Units" group > Click "Change" > There'll be two option available change it and then > File > Save as > Set ".STEP" format then open into solidworks and see.
Thanks and Regards
Venkatesh S
Application Engineer
E G S Computers India Pvt. Ltd.
http://www.egsindia.com | http://www.egs.co.in | http://www.egsindia.blogspot.in
Check units of the default template you're using if those are in MM or not. Also verify the diameter if the model once you import the file into SW.
