Hello There,
I'm using SolidWorks 2015 SP 2.0, when i try to open a large assembly is crashing with dbghelp.dll (event viewer)while opening in Large Assembly Mode/Lightweight mode... There is no issue, while opening in resolved mode.
Please help, if anyone have came across this issue.
Sai
Try opening the assembly in the Solidworks RX mode and click below link(in the image). Try to open the assembly in this mode.
But this is not the solution.It is just a process to check if there is no problem in the assembly.
Contact your Solidworks vendor and get the Solidworks settings file .SLDREG file(and run this file before you open Solidworks for better performance)
