I'm doing a steady-state simulation,
in"solver" window, the progress column shows the goal was achieved
however, it seems that calculation still continues and goal temperature seems stable
should I just stop calculation and save current result ?
Another question is about transient flow simulation
I set physical time to 270 s
few of volume goals achieved early (about 30 s physical time )
does it mean the steady state have already been achieved?
If you set the time to 270s, your simulation will continue until that time. "Steady state" can be a subjective term. If you see that your critical parameters have settled into a more or less constant value, then you could consider that steady state.
