PFPaul Flores10/03/2015
The below macro, found on this forum, exports mass and COM (to Excel) of all parts in an open assembly.
Dim SwModel As SldWorks.ModelDoc2
Dim swModExt As SldWorks.ModelDocExtension
Dim swAssembly As SldWorks.AssemblyDoc
Dim SwComp As SldWorks.Component2
Dim MassProp As SldWorks.MassProperty
Dim Component As Variant
Dim Components As Variant
Dim Bodies As Variant
Dim BodyInfo As Variant
Dim CenOfM As Variant
Dim RetBool As Boolean
Dim RetVal As Long
Dim xlApp As Excel.Application
Dim xlWorkBooks As Excel.Workbooks
Dim xlBook As Excel.Workbook
Dim xlsheet As Excel.Worksheet
Dim OutputPath As String
Dim OutputFN As String
Dim xlCurRow As Integer
Set SwModel = swApp.ActiveDoc
If SwModel Is Nothing Then
        swApp.SendMsgToUser2 "An assembly must be an active document.", swMbWarning, swMbOk
        Exit Sub
If SwModel.GetType <> swDocASSEMBLY Then
        Exit Sub
Else
Set swAssembly = SwModel
Set swModExt = SwModel.Extension
Set MassProp = swModExt.CreateMassProperty
OutputPath = Environ("USERPROFILE") & "\Desktop\"
OutputFN = SwModel.GetTitle & ".xlsx"
If Dir(OutputPath & OutputFN) <> "" Then
Kill OutputPath & OutputFN
Set xlApp = Excel.Application
xlApp.Visible = True
Set xlWorkBooks = Excel.Workbooks
Set xlBook = xlWorkBooks.Add()
Set xlsheet = xlBook.Worksheets("Sheet1")
xlsheet.Range("A1").Value = "Component"
xlsheet.Range("B1").Value = "X Loc (mm)"
xlsheet.Range("C1").Value = "Y Loc (mm)"
xlsheet.Range("D1").Value = "Z Loc (mm)"
xlsheet.Range("E1").Value = "Mass (kg)"
xlsheet.Range("F1").Value = "Type"
xlBook.SaveAs OutputPath & OutputFN
xlCurRow = 2
RetVal = swAssembly.ResolveAllLightWeightComponents(False)
Components = swAssembly.GetComponents(False)
For Each Component In Components
    Set SwComp = Component
    If SwComp.GetSuppression <> 0 Then
    'If LCase(Right(SwComp.GetPathName, 3)) <> "asm" Then
        Bodies = SwComp.GetBodies2(0)
'MsgBox SwComp.Name
        'If Bodies <> Empty Then
            RetBool = MassProp.AddBodies(Bodies)
            CenOfM = MassProp.CenterOfMass
            xlsheet.Range("A" & xlCurRow).Value = SwComp.Name
            xlsheet.Range("B" & xlCurRow).Value = CenOfM(0) * 1000
            xlsheet.Range("C" & xlCurRow).Value = CenOfM(1) * 1000
            xlsheet.Range("D" & xlCurRow).Value = CenOfM(2) * 1000
            xlsheet.Range("E" & xlCurRow).Value = MassProp.Mass
            If LCase(Right(SwComp.GetPathName, 3)) = "asm" Then
            xlsheet.Range("F" & xlCurRow).Value = "Assembly"
            ElseIf LCase(Right(SwComp.GetPathName, 3)) = "prt" Then
            xlsheet.Range("F" & xlCurRow).Value = "Part"
            Else
            xlsheet.Range("F" & xlCurRow).Value = "Undetermined"
            End If 'Right 3 of file extension
            xlCurRow = xlCurRow + 1
        'End If 'UBound(Bodies) <> -1
    'End If 'Not an Assembly
    End If 'swComp.GetSuppression <> 0
Next Component
xlsheet.UsedRange.EntireColumn.AutoFit
xlBook.Save
'xlWorkBooks.Close
'xlApp.Quit
I was wondering how to modify it to export only parts with properties that meet a certain criteria. We have a configuration specific property in our parts called "Type" and we fill in "plate", "sheet", "round bar", etc.  What I need the macro to do is find the parts that have the "Type" property with either "plate" or "sheet" filled in, then export only those files to Excel.
Here are what the columns in Excel would be:
xlsheet.Range("A1").Value = "Filename-configuration"
xlsheet.Range("B1").Value = "Type"
xlsheet.Range("C1").Value = "Description"
Any help would be appreciated.
