I am attempting to extend the curved white ribbon all the way up the cone, but I'm struggling with the helix and making it extend all the way past the top of the cone to extend the ribbon part. Any suggestions? Thanks in advance for your help!
See if the method in the attached example will work. If you look closely the spiral doesn't quite go all the way up and into the green ball. To fix this I would recommend adding the swirl before the ball is there so you can extend it up closer to the tip. Then add the ball over it.
