I'm trying to take a screenshot of an assembly when measuring the distance between two points.
And, no I don't want to put it in a drawing
If you mean that you want the dimension that appears in the graphics area to be a larger font, then no, I don't believe you can do that.
If you don't want to create a drawing, then the only thing I can think of would be to create a sketch, with a point at each of the points you want to dimension to, and place a dimension between these two points in the sketch. You can change the font for dimension text.
