Hey. I have one big problem. I made custom pipe and custom flange and also custom template for routing., but when I want to create routing it show me message: No valid configuration for this pipe. Does anyone knows where is the problem? I attached flange, pipe and template part.
Jack,
A quick look at the designtable of your flange shows that you are missing some data.
You don't seem to have Cpoint or Rpoint but instead you have Apunkt and Lpunkt.
That may be fine because of the language you are working in but nevertheless that means that you should still have at least the equivalent of a Diameter@Cpoint1 in your design table. You also seem to be missing "Axis of Rotation" as well as a "Vertical"
Easiest way should be for you to use the Routing wizard to check your flange, pipe and any other parts.
Concerning your pipe, you would do well to read up on $prp@Pipe Identifier, NominalDiameter@FilterSketch and $prp@Specification.
Have a nice one
Peter
