8 Replies Latest reply on Mar 10, 2015 6:11 AM by Deepak Gupta
    How can I get the hole callout to show the correct decimal marker?
    Janek Popiolek
      Dimensions in metric drawings to BS 8888 and ISO use the comma as the decimal marker.
      But in hole callouts the information uses the dot as the decimal marker (see image).
      This goes for decimal numbers in sheet metal bend lines and weight parameters leading to an embarrassingly inconsistent drawing.
      Is there any way to set the comma for all of these values?
      Note:  Nothing appears in the calloutformat.txt file of course.
      Thank you.
