Here I expose my inexperience / ignorance...
I have a surface that I want to place a fill pattern on half of... So I split the surface with a sketch and create my fill pattern. Now I want to make the original surface continuous again. Any suggestions on the best way to do this?
Thanks!
-Nate
Alin,
I tried all the combinations of Delete face on a little test part that looked sort of like Nathan's picture. No joy. So I just deleted the Split Line feature and changed it's sketch from a line to a rectangle, then edited the fill pattern to use the rectangle as the fill boundary. I also had to edit the sketch plane for the little bumps since I had made it after the split face, but that was simple enough. Without adding more features, that seems to be the simplest way to go, unless there is more to Nathan's part than meets the eye.
