Dear Solidworks users,
Good Day.
I would like to seek your professional help regarding the routing feature of solidworks.
I already spent a week aiming to solve this problem I encountered.
This is regarding the flange to flange connections withing the same route assembly.
I attached jpg files showing my problem.
When using the Solidworks' default flange components I am able to connect flanges easily and it even automatically mate itself to the other flange.
however when I created our companies' own standard libraries and followed the routing wizard in creating flange it still fail.
I compared the solidworks' default and even tried to copy the settings for the mate reference, however it still won't mate.
Am I missing something?
I really appreciate your help on this.
We will be starting to use the piping library by next week and hoping someone can help me with this concern.
Thank You Very Much.
Regards,
Randy
Concerning Cpoint2 and Rpoint2 :
You have two options, the easy one is indeed to make the 20K a seperate part. However I can understand the reluctance to do that because what if you have to change from a 10K to a 20K. You can do it by replace fitting but it's a tad more of a hassle.
The more intricate one is constructing your part in such a manner that you still have only 1 Cpoint and 1 Rpoint but that there position is determined in such a manner that they are still in the correct position no matter if a raised face or not.
Having more then the required Cpoints and/or Rpoints, no matter if surpressed or not, does screw up the routing functionality.
Try this, make a copy of your flange. Delete the Cpoint2 en Rpoint2 and see if now the flange behaves as it should, and as you expect, when using in a routing.
Concerning Designtable
The only thing that I notice in a glance was that you aren't using a $prp@description , which surprised me because how are you going to populate the BOM?
Concerning specification@cpoint
For the rest, read, experiment, dig into the helpfiles and bother your VAR.
Routing is great, when it works as it should, but it takes a while to get to grips with it.
It does ask for lots of experimenting and learning.
Have a nice one
Peter
