Import 3D dxf/dwg to new part as 3D curves or model
Question asked by Ryan Gerry on Mar 5, 2015
I am trying to replicate the SW function that imports a dxf/dwg to a new 3D model through API.  When recording the macro, it used LoadFile2, but that imported the dxf onto a drawing.  I then tried using LoadFile4 and importdata, which imports it to a 2d sketch..
Here is the code that imported it to a 2d sketch:
Option Explicit
Dim Part As Object
Dim importData As SldWorks.ImportDxfDwgData
Dim filename As String
Dim longerrors As Long
filename = "X:\Patrick\From Ryan\Enclos DWGs\ST91-16-019_3D.dwg"
Set importData = swApp.GetImportFileData(filename)
importData.ImportMethod("") = SwConst.swImportDxfDwg_ImportToExistingPart
Dim newDoc As SldWorks.ModelDoc2
Set newDoc = swApp.LoadFile4(filename, "", importData, longerrors)
Thanks for any help!
