Yesterday I was working on a large assembly and when I added a new part. Went to sketch the profile and needed to add some relations to that sketch.
When I select the add relations command, it will let me select the lines to add relations to, but does not present any relations to add to those sketch lines. Is there a option I may have accidentally turned off or one that could have turned itself off? Seeing as I would remember turning off a setting. Thanks for any help in advance guys!
Update:
I went back to the sketch and without selecting the "add relations" command I selected the line and arc I needed to add relations to using the shift key. As soon as I did that it brought up relations I could add on the left hand tool bar. I used this method for the rest of the sketch relations I needed and it seems to have worked. Odd because I had to add relations the other way up until this point.
I've always used Ctrl when selecting sketch entities to apply relations. Maybe I'm missing something, but why are you using Shift?
And I've never activated the "Add relations" command. I just hold down Ctrl while selecting the entities, then release the Ctrl key. The entities stay selected and the context toolbar pops up in the graphics area with the available relations to select. I can also set relations in the PropertyManager that pops up when Ctrl selecting 2 or more sketch entities. (The toolbar shown below is only available for sketching in Parts and Assemblies, not Drawings, but you can still use the PropertyManager.)
