16 Replies Latest reply on Aug 14, 2015 12:42 PM by Deepak Gupta
    Macro to delete dangling centermarks
    David Dewey
      I am running a macro that currently deletes dangling dimensions and notes.
      However, we heavily use centermarks and centerlines here. I was wondering if there was a way to find those two elements and determine if they are dangling as well?
      I can share the code I found here if that would be helpful.
        • Re: Macro to delete dangling centermarks
          Keith Rice
          Please post a simple drawing with such a "dangling centermark".
          Keith
          SolidWorks API Training
            Deepak Gupta
            Yes, you can loop thru the drawing and find the centermarks and centerlines, check whether there are dangling OR not, and then delete them.
            I think you're using this macro Re: Delete dangling dimensions from Adam Hoffman
            If yes then you need to edit these line:
            If swAnno.GetType = 4 Then
            Change 4 to 13 for centermarks and 15 for centerlines
            bSelect = swModel.Extension.SelectByID2(sItemName + "@" + CStr(swView.Name), "DIMENSION", 0, 0, 0, True, 0, Nothing, 0)
            Change DIMENSION to CENTERMARKSYM for centermarks and CENTERLINE for centerlines
                David Dewey
                Hello Deepak,
                Thank you for the quick response. This does work and I am sure I can get it to work to delete centermarks, centerlines as well as dangling dimensions, However what would be the most efficient way to structure this code? If then else statements to include centermarks and centerlines in the main if then for searching for type?
                '                            Clean Up Drawing Macro                              '
                'Macro will traverse through all drawing views
                'and delete dangling dimensions and notes
                'Written by Adam Hoffman
                'Was written using SolidWorks 2014 SP 2.0
                'This macro is provided as is and the creator is not responsible for any mishaps
                Dim swView As SldWorks.View
                Dim swAnno As SldWorks.Annotation
                Dim sAnnoType As String
                Dim swNote As SldWorks.Note
                Dim bSelect As Boolean
                Dim bDeleteFlag As Boolean
                Dim sItemName As String
                Const swDrawingDoc = 3
                Const swAssemblyDoc = 2
                Const swPartDoc = 1
                Sub CleanUpMain()
                Set swModel = swApp.ActiveDoc
                'If the active document is not a drawing exit program
                If Not swModel.GetType() = swDrawingDoc Then
                   MsgBox ("You Must Run This Macro Inside Of A Drawing!")
                   Exit Sub
                ElseIf swModel.GetType() = swDrawingDoc Then
                   Set swDraw = swModel
                swModel.ClearSelection2 (True) 'Make sure all selections are cleared before you start
                bDeleteFlag = False
                Set swView = swDraw.GetFirstView 'This is the overall drawing itself
                Set swView = swView.GetNextView 'This is the actual first view in the drawing
                'Start the loop through views in the drawing
                Do While Not swView Is Nothing
                   'Start the dangling Note removal
                   Set swNote = swView.GetFirstNote
                   Do While Not swNote Is Nothing
                      sItemName = ""
                      sItemName = swNote.GetName()
                      Dim sNoteText As String
                      sNoteText = ""
                      sNoteText = swNote.GetText()
                      'I found when dealing with notes this was more reliable
                      'than using the swAnno.IsDangling method
                      If sNoteText = "?" Or sNoteText = "" Then
                         bSelect = swModel.Extension.SelectByID2(sItemName + "@" + CStr(swView.Name), "NOTE", 0, 0, 0, True, 0, Nothing, 0)
                         bDeleteFlag = True
                      Set swNote = swNote.GetNext
                   Loop
                   If bDeleteFlag = True Then
                      'After going through all the notes in this view delete the ones that have been selected
                      boolstatus = swModel.Extension.DeleteSelection2(2)
                   'End of dangling Note removal
                   bDeleteFlag = False
                   boolstatus = False
                   'Start the dangling dimension removal
                   Set swAnno = swView.GetFirstAnnotation3()
                   Do While Not swAnno Is Nothing
                         sItemName = ""
                         If swAnno.IsDangling Then
                            sItemName = swAnno.GetName()
                            bDeleteFlag = True
                      Set swAnno = swAnno.GetNext3()
                   Loop
                      'After going through all the dimensions in this view delete the ones that have been selected
                   'End of dangling dimension removal
                Loop 'End of loop through drawing views and overall program
                David Dewey
                Thank you Deepak. I just saw this now. I will contact our VAR. In the meantime, do you know what we would need to add dangling ordinate dimensions? I've poked around a bit but haven't been able to see how to get them selected.
