I want to be able to work on files on a personal version of SolidWorks Student Edition, but I don't want to encounter any errors when using the files on both systems.
I'm pretty sure you'll be okay going back and forth between the two as long as they're the same versions (both SW2014 - 2015, for example). If they aren't the same then the older version won't be able to open files saved with the newer one. Someone else can probably verify this.
