Toolbox / Hole Wizard
Question asked by Trevor Sheen on Mar 4, 2015
I'm trying to create a custom hole configuration for when I am designing injection mould tools. I need to modify the counterbore dimensions to suit various core and ejector pins etc.
I have the option to copy an existing configuration and modify it.
However, as I would like to add some under head countersink info to the counterbore I have discovered I am unable to add a new column to the hole wizard properties. Also I would like to remove some information and also remove some of the standard features that have been copied across, this cannot be removed either.
Is there a way to do this and truly customize the hole wizard? Or is a better option to create favourites and use them in the drop down menu?
Thanks in advance.
