Hi all,
I am having major issues trying to enable this loft to work, I had the initial version working however I have updated this one to ensure all sides have draft angles as it is to be layed up with carbon fibre in a machined mould.
I am sure someone experienced may detect the error quickly, any help is much appreciated.
Attached is the part.
Sam
I only tried a little, and didn't get it to work either, may play some more, but here's some ideas. I assume you're doing this as a surface.
You mention loft, are you trying surface loft or boundary surface? Give boundary surface a shot if you haven't. Have you tried doing it in sections or just all in one shot? Doing it in sections may not be the solution, but maybe it will reveal a problem area (one section won't loft).
Good luck, looks interesting.
