when I zoom to fit my assembly zooms far away out of sight and I can not find another part that would be so far away from my assembly how do I find it
You can click on a part in the tree and choose the "Zoom to Selection" icon. That will take you to the part.
Another option would be to just click and drag a selection box over what appears to be open space in your graphics area. If there are any parts within that area they should be highlighted in the tree.
I have found all the parts on the tree if I choose top view it works fine if I choose isometric view it zooms out of sight
Once in awhile a part goes into outer space or you have a dimension that went way out, find and delete it. The way to find which one it is - Suppress every component and then one by one un-suppress each component and after each un-suppress hit the "F" key, when it zooms into outer space delete the last part or dimension
Can be a challenge to find
