2 Replies Latest reply on Mar 3, 2015 10:10 AM by Andy Braham
    AddDimension2 text location
    Andy Braham
      Hello everyone,
         I have a simple question about how to enter the position of the text in a Model Sketch. When using the ModelDoc2::Extensions::AddDimension2 the position of the text is defined by the xyz values, the problem that I am running into is the coordinates are based on the Model not the 2D sketch. So for example if I sketch on the Right plane the coordinates for 1,2,0 are actually 0,2,1 because the plane is on YZ. Am I using the wrong method to create the dimensions? I looked under the SketchManager and did not see any methods for creating dimensions.  Or is there a easy way to convert the Model Coordinates to the Sketch Coordinates?
      Thanks for the help!
      Andy
        • Re: AddDimension2 text location
          Keith Rice
          Andy,
          If the coordinates you want to use are relative to the model, you need to transform them relative to the sketch, which is accomplished via ISketch::ModelToSketchTransform. Check out the API Help example "Transform Coordinates from Sketch to Model Space Example (VBA)". Note that this transforms from sketch to model, if you want to do the opposite then you would simply remove this line so as not to invert the transform:
          Set swMathTrans = swMathTrans.Inverse
          Keith
          SolidWorks API Tutorials
              Andy Braham
              Thank you Kieth, that is exactly what I was looking for.
              In case anyone else is trying to figure this out here is a quick snippet
              Dim swPart As SldWorks.ModelDoc2
              Dim swSketch As SldWorks.Sketch
              Dim swMathUtil As SldWorks.MathUtility
              Dim swMathTrans As SldWorks.MathTransform
              Dim swMathPt As SldWorks.MathPoint
              Dim pntSketch(2) As Double
              Dim pntModel() As Double
              Set swPart = swApp.ActiveDoc
              Set swMathUtil = swApp.GetMathUtility
              Set swSketch = swPart.GetActiveSketch2
              Set swMathTrans = swSketch.ModelToSketchTransform
              pntSketch(0) = 1.5
              pntSketch(1) = 3.25
              pntSketch(2) = 0
              Set swMathPt = swMathUtil.CreatePoint(pntSketch)
              Set swMathPt = swMathPt.MultiplyTransform(swMathTrans)
              pntModel = swMathPt.ArrayData
              Debug.Print "Sketch point: " & pntSketch(0) & ", " & pntSketch(1) & ", " & pntSketch(2) & ", "
              Debug.Print "Model point: " & pntModel(0) & ", " & pntModel(1) & ", " & pntModel(2) & ", "
