Re: How do I import a pencil sketch into SolidWorks?
Jeff Mirisola Feb 28, 2015 3:28 PM (in response to Stephan Bianchi)You can scan it, and save it as a picture file. In SolidWorks, start a new sketch then go to Tools->Sketch Tools->Sketch Picture.
The help files have a section on Sketch Picture as well.
Peter Thannhauser Feb 28, 2015 3:31 PM (in response to Stephan Bianchi)Scan your image if its in paper format, bring it in as background, stretch/reduce scale against real world reference dimensions, then commence drawing your SW sketch geometry 'on top'. This video shows the basic workflow. I suspect there are additional resources by searching the web.
Solidworks How To Insert a Image - YouTube
This is kind of high speed (because its essentially a teaser ad for the person providing tutorial dvd) but shows the way he uses same process in all three overlapping image dimensions (top, side, front) & works it from there.
SolidWorks Tutorial : How To Model a F-16 in SolidWorks - YouTube
Jeff Holliday Mar 2, 2015 9:12 AM (in response to Stephan Bianchi)Following up on Jeff's suggestion, there is also an "autotrace" function that can be turned on/off for use with the sketch picture. I would not suggest using it for graphically-confusing sketches, but it may work for simple ones. The autotrace is toggled on/off as an add-in.
