3 Replies Latest reply on Mar 3, 2015 8:52 PM by Jared Conway
    CREATING MULTIPLE RENDERINGS WITH DIFFERENT CAMERA ANGLES?
    Ryan Politowski
      So im looking to make like 20 or so photos or renderings of a modeled assembly. i would like to set up a camera in photoview and render the object. i then would like to slightly have that camera rotate a few degrees and then complete another rendering. i want to do this quit a few times all the way around the model. so far while looking into this i havent seen a setting that will just rotate the camera a couple degrees spherically around my model. its important that i keep the same height and other settings the same for each one. when im done a co-worker is going to take those pictures and make a simulation of the model rotating. just like a simulation. i hope i explaned this well enought as im still kinda new to photoview and rendering as a whole. is there an easy way of accomplishing this? i feel like i should be able to set up a default camera, render it and then rotate a little and render again. and so on.... anyone have any insight? thank you
