According to SolidWorks, the issue with Pack and Go color highlighting (SPR # 833725) was fixed in 2015 SP2, but after installing SP2 today, I still am not seeing the color highlights changing with Save To Name or Save To Folder changes. Anybody else experiencing this? Is there a settings change, perhaps in the System Options -> Colors that needs to be changed as well?
Having exact same problem. The colors only change if you double click each cell and change the values individually, however it doesn't work when using Select/Replace. VAR is looking into it currently. Strange how its now broken, considering the UI and functionality has remained unchanged for years.
