Could someone explain how to do intake monifold flow analyse?
To the intake tube i set 2bar pressure, (environment, static or total? which and why?)
Ant second: to the outlet ports: which pressure tipe should I set, and how mutch pressure? 1 bar or vacuum? why?
and one more question: should i set analyses time?
Thanks a lot
The online help file outlines exactly what is the difference between environmental, static, and total in context of Flow Sim, have a read through it. I usually set inputs as static and outputs as environmental. Analysis time is not something you should mess with unless your simulation is extremely unstable and you want a finer temporal resolution (lowering your time step will come at the cost of computational time.)
