2 Replies Latest reply on Mar 5, 2015 12:56 PM by John Burrill
    How do insert a formula into a note?
    Ronan Carrroll
      My problem is; I want to add mass properties to my drawing sheet formats but some of the models have their mass listed in grams and others kilograms. The length units I use are mm.
      I tried setting the drawing template mass units to Kg and then link the note to the component mass. That just lists the component mass in grams if its mass units are set to grams.
      Next plan Use a formula "" to display the mass.
      Ideal note would look like
      Weight:- density x volume / 1000 Kg
      Can this be done?
