Dear Solidworks user
- What are all output plot need to consider for cavitation?
- In solid works flow simulation manual it show only density plot, in that the blue regions in the cut plot represent very low density regions. Which indicate that cavitation is occurring in these regions. But is there any criteria to check for cavitation?
Senthil Ramajayam
flow simulation tells you if cavitation is happening and how large the region is
you can compare against other designs and see if it is larger or smaller and if the region changes
beyond that i am not aware of any further criteria
density plot is the easiest but there is also % vapor charts that can visualize the cavitation
