There might be two things I miss from the old Acad days, & one is something
I’m looking for in SW. I have a part that starts off fairly simple but then winds around
with sweeps, including splines. I get to the other end totally out of any kind of sensible
orientation, & I need to do some work. In Acad/Mdt, I could just create a UCS at that point
maybe by 3 points of geometry, & I could go to a working environment in
that USC. In SW I created the UCS, but it doesn’t seem to allow for me to move
into a work environment within it. What am I missing?
When trying to work on complex areas way
off away from the coordinate system how do you do it in SW?
Thanks, in advance for any input;
Rob_D SW 2014_Sp4
Typically, when I teach SW to AutoCAD users, I find it's a lot harder than teaching somebody with no experience. It's because AutoCAD thinking is totally unrelated to SW thinking.
If you post an example of what you would like to do, I can tell you the SolidWorks way to do it, and you can judge whether you can get used to it.
