Tolerance vertical justification on drawing dimension?
Question asked by Dave Krum on Feb 25, 2015
Latest reply on Feb 25, 2015 by Dave Krum
Hello All,
Quick question on something I'm probably missing that is so easy, its ridiculous.  I don't usually use tolerances on dimensions but have an instance where I need to show it on a drawing for one of our steel suppliers.  The upper horizontal dimension has the tolerance shifted up from the nominal dimension which I don't like.  I prefer the bottom one that shows the tolerance center justified vertically.  I cannot find a setting to change this.  I cannot reproduce the same bottom dimension again either, I get the same result as the top one so I must have inadvertently changed something.  Please see markup below.  I'm on SW2010 and don't see an option.  Didn't see anything on web after using above search phrase. Thanks!
