I am doing a thermal flow simulation study for a PCB enclosed in a closed box, i have datasheet of the components that are being used.
I am not able to figure out what values i would be putting in the simulation for temperature of the individual components.
I really need some help here.
Thanks...
what is the goal of your analysis? generally with electronics cooling it is to find the temperature of the components.
so normally you would input what the power is going into the components and based on the flow, you will get the temperature of the components.
