When I change a view the following error appears:
Anyone know how to fix this?
Thank you in advance!
Congratulations! You'v3 discovered a new art form.
Run the SolidWorks Rx > Diagnostics tool to see what it reports.
You are right! haha I'm not fixing this problem! Just kidding!
I've run SolidWorks Rx and I got this error:
It makes sense since my onboard video card is not listed by Solidwoks (Intel HD Graphics 4400), however, I do have an offboard video card (AMD Radeon R7 M265) which I guess is not listed as well.
Is there a way to fix this?
Finally a conclusion, this is a problem caused by a non "approved grafic card".There are 2 ways to get around this problem:
1 - Buy an approved grafic card (Recommended)
Graphics Card Drivers | SOLIDWORKS
2 - Use RealHack, but it only works at ATI Radeon and Nvidea grafic cards
RealHack - RealHack 3.7 para SolidWorks 2010 - 2014 - Portal CAD (Automatic)
Tutorials featuring RealView, in SolidWorks 2015 - GrabCAD (Manual)
Tutorial (Portuguese) - SolidWorks3D: Ativação do RealView em placas de videos não homologadas
Try making SW recognise the Radeon card. You may have more luck with that even though it is not listed.
Once SW is using the Radeon card you could try using RealHack to soft-mod the card.
