I am using X-Formation License Statistics to track and report usage in Solidworks. After a recent upgrade to Solidworks Solidnetwork License Manager 23.1.1.0002 (11.11.1.2), we are unable to pull info from the Solidworks NLM. X-Formation technical support says their program must be able to get output from lmutil lmdiag -n -c port@server_name.
When I run this command either from the reporting server, or even locally on the Solidworks NLM itself, I get no output as follows:
C:\Program Files (x86)\SolidWorks Corp\SolidNetWork License Manager\utils> lmutil lmdiag -n -c 25734@sw_nlm1
lmutil - Copyright (c) 1989-2013 Flexera Software LLC. All Rights Reserved.
FlexNet diagnostics on Mon 2/23/2015 15:00
License file: 25734@sw_nlm1
This works fine on every other FlexLM based server (Autodesk, PTC, National Instuments), but not this one. I know the Solidworks NLM is working fine because users are pulling licenses. I just cannot run any usage reports if LMUTIL is not reporting back any information.
Any help would be appreciated.
Thank you
Raymond
IT WORKED! I am happy to report that switching from "Network Activation" to an actual License file did the trick! Using an actual license file now, and X-Formation License Statistics can now monitor and report on Solidworks usage! All good!
