Hi, I`m junior, make a box for consumer electronics. The Help says " Draft Analysis PropertyManager" that it can be corrected using --> Displays faces that contain both positive and negative draft. Typically, you can eliminate a straddle face by creating a split line. Split line is already there ,
but the problem remains!
Сan not understand how to fix "straddle face"?
Andy
It looks like the subd mesh is the issue, the facets are not parallel to the parting line that you want.
I drew a red line on these images for reference. Though you may want the actual parting line higher or lower, its still the same issue, the true parting line (which you can check for yourself using the parting line feature) is not on a plane.
Did you start from a primitive (like a box or sphere) in PowerSurfacing, or did you create the subd mesh in another application?
