When I scroll over a button I wish the tool tip would say what short cut to use in the future to do the same thing. For example, in Libreoffice if I hover over print, it will tell me the shortcut is control P. If you know of an option to enable this it would be awesome. Thank you.
The tool tip should show the assigned shortcut. In case there is no shortcut assigned then you'll not see anything.
You can set the shortcuts under Tools > Customize >Keyboard tab.
