The current output from solid works thermal analysis is W/m2 , which I believe its the in the node of the mesh. So please advice if there is a way in solid works which allow to display the heat flux unit as W?
thanks in advance ...
Heat flux is defined as the amount of heat transferred per unit area per unit time from or to a surface.
