I've imported AB manufactured parts library.
Some of PLCs I want to use are type "module without interface".
When you attempt to select the manufactured part to associate with PLC, I can only select type PLC or base?
Can you change the options or do you need to change the part type?
C>program Data> Solidworks Electrical>catolog> parts>ABB
after update , in select menu you should unactivate in the class section .
Then write reference number. İf you could not find
