3 Replies Latest reply on Mar 10, 2015 11:44 PM by Kasun Udayanga
    Get coordinates point in a sketch (Problem negativ/positiv value)
    Charles Robin
      Hi everyone
      I use this code to get the point coordinates where i just clicked with my mouse:
      Its working if i select a sketch point, and also if i click on 3D Model surface.
      Dim Part As ModelDoc2
      Dim SelMgr As SldWorks.SelectionMgr
      Set Part = swApp.ActiveDoc
      Set SelMgr = Part.SelectionManager
      Dim point As Variant
      point = SelMgr.GetSelectionPoint2(1, -1)
      Debug.Print point(0) 'X
      Debug.Print point(1) 'Y
      Debug.Print point(2) 'Z
      I don't know why, sometime, when i'm editing a sketch, the coordinate axes can be reversed:
      As you can see in this example, the 'X' axe of the sketch is in a reverse sens of the 'X' axe of the 3D model.
      So if i click on a sketch point, i have the sketch coordinates.
      And if i click on the surface of the Model, i got the 3D model coordinate  ...:  the negative of the X sketch coordinates, even if its in the same location.
      Then if i want to insert a block in the sketch, by the way of clicking on the Model surface,
      the block will appear in the symetrie of 'Y' axe, because  X = - X.
      Can you have a solution to coordonate (haha) the landmark?
      Maybe a different code or a VBA trick?
      Thank you very much!
