I want to model the deflection of a "reed valve" due to flow though a hole. Is it possible? the reed valve is flat crossed the hole and when flow beings the reed valve is deflected away form the flow. is it possible to model that deflection buy just doing flow?
there is no fluid structure interaction in solidworks simulation
but you can do a decoupled analysis where you run the flow and then find the displacement due to the pressure
or move to something like abaqus that can couple them together
