I need to make 20 Varible Radius fillets (probably 60 when I find out that SW won't let me pattern them). All the edges are the same length, I need all the bottom radi to be .1 and all the top radi to be .122. Sure would be nice to be able to input .1 and .122 somewhere and then select the edge and be done with it...maybe a "flip" button if the radi appear on the wrong end of the edge. As it is now you have to select 1 edge, input the radius into 1 fly out box (after rotating your part around to find out what box is for what radius), input the other radius into the other flyout box, repeat all this 20 times and hope you don't type in the wrong number while typing your 40 inputs! (120 inputs when I find out the pattern does'nt work).
See attachment.
Thanks-
Assuming there is no easy way (which I doubt), I would try..
making a surface body of the before, add the fillet, cut with the surface to make that filleted region its own body, copy/array the fillet body as needed, then combine them all to the main body.
