1 Reply Latest reply on Feb 17, 2015 2:56 PM by Ivana Kolin
    Sketch Text Count
    David Dewey
      I am running the following script. The script looks at all the sketch text within a sketch and renumbers them based on their insertion order starting from zero. There is a maximum of 144 text entities and a minimum of some number under that. What I'm unsure of is how to get the actual count of entities so I can run my FOR loop without going out of range and popping up an error dialogue each time. Any help on how to get this count would be appreciated!
      ' Preconditions:
      '           (1) Part document is open and contains
      '               sketch text.
      '           (2) Feature for sketch text is selected.
      ' Postconditions: All text is updated in numeric order starting from 0.
      Option Explicit
      Dim swModel As Object
      Dim swFeat As SldWorks.Feature
      Dim swSketch As SldWorks.Sketch
      Dim swSketchText As SldWorks.SketchText
      Dim params As Variant
      Dim i As Integer
      Dim Sketchid As Integer
      Dim TextCount As Integer
      Set swModel = swApp.ActiveDoc
      ' Get the selected feature of the sketch text
      Set swFeat = swSelMgr.GetSelectedObject6(1, 0)
      Set swSketch = swFeat.GetSpecificFeature2
      ' Edit the sketch of the sketch text
      swModel.EditSketch
      'vSketchTextSegments = swSketch.GetSketchTextSegments
      ' Get the sketch text
      params = swSketch.GetSketchTextSegments
      ' Only one instance of sketch text so
      ' set SketchText to that instance
      'GET TEXTCOUNT
      'TextCount =
      'ATTEMPTED FOR LOOP
      For i = 0 To 144
          Set swSketchText = params(i)
          swSketchText.Text = i
      Next i
      ' Insert the new text in the sketch,
      ' rebuild the part with any changes
      ' made to the sketch, and
      ' exit sketch mode
      swModel.InsertSketch2 True
        • Re: Sketch Text Count
          Ivana Kolin
          Option Explicit
          Dim i As Integer
              swModel.EditSketch
              'GET TEXTCOUNT
              '  ***** solution a
              Dim param As Variant
              TextCount = 0
              If (Not IsEmpty(params)) Then
                  For Each param In params
                      swSketchText.Text = TextCount
                      TextCount = TextCount + 1
                  Next
              '  ***** end   solution a
              '  ***** solution b
              TextCount = 0
                  TextCount = UBound(params)
          '    'ATTEMPTED FOR LOOP
              For i = 0 To TextCount
              Next i
              '  ***** end solution b
              ' exit sketch mode
