Hello
I have two examples, I want to how I can simplify this items and reduce file size to use it in my main assembly to check intereference and how does it fit and work in my main assembly, there are bought out item so only mounting details and outer geometry is important.
thanks
Regards
Yogesh
If the imported file has many bodies delete any unnecessary bodies. Then I'd suggest extruding solid blocks/shapes over any complicated features to simplify the outer geometry. Once you are done with that export to a parasolid or other dumb format and re-import it so that it just has the single import feature. Hopefully that will work for you.
