Our customer has sent us a drawing, but is unable to send us a solid model.
The part requires a ball mill to cut a series of rounded slots in the face of a part.
The drawing shows the profile of the slot (the guide curve) as a 2-d sketch, and the length of the slot in radial degrees.
I fully understand the sketch, and I also understand the intent... but I am unable for the life of me to get SW to let me wrap the guide curve around the necessary diameter.
I am using a closed sketch, assuming I could simply Insert->Features->Wrap->Scribe and then grab the profile to drive my radius cut... but I am unable to complete the wrap operation, "Wrap failed, could not use any contour(s) from sketch.
Could any gurus please explain it to me in small words?
This may not be the easiest or most elegant solution, but I think the end result is good. I drew the path as it is shown on the drawing, then I offset it to get the path of the center of the ball. Then I made a closed contour out of it, wrapped it onto a 90 mm dia surface, and converted wrapped path into a 3D sketch. Then I used that as a path for a sweep of a circle, and finally I used revolved cuts to finish off the ends.
