4 Replies Latest reply on Feb 19, 2015 10:39 AM by Charles Robin
    Edit Configurations Properties Alternates Name of all the component in assy
    Charles Robin
      Hi everyone
      i would like to create a macro who change the alternate name of all the composant in an assembly.
      The alternate name is the "part number displayed when used in a bill of materials".
      I got a macro to change the active document alternates names of all config..
      How to get the alternate name of a child (component in a assembly)?
      Thank you very much!
          • Re: Edit Configurations Properties Alternates Name of all the component in assy
            Charles Robin
            Thank you Deepak Gupta
            I reminds you that i m not asking how to get the config name, but the alternate name in config properties.
            Here an example to get the alternate name  in the case of the Active Document:
            2012 SOLIDWORKS API Help - Change Configuration Properties Example (VBA)
            but i dont found what is the instance in the case of a Children Component.
            instance.AlternateName = value
            value = instance.AlternateName
            i've try this but its not working:
            swApp.ActiveDoc.GetConfigurationByName(vConfigName).AlternateName
            become....
            svChildComp.GetConfigurationByName(vConfigName).AlternateName
            I wonder if it is possible to get the alternatename without open the child component file..?
            thank you
                Deepak Gupta
                I wonder if it is possible to get the alternate name without open the child component file..?
                thank you
                Here are the codes you can use to get alternate name of selected component's configuration used in assembly.
                    Dim swApp                   As SldWorks.SldWorks
                    Dim swSelMgr                As SldWorks.SelectionMgr
                    Dim swModel                 As SldWorks.ModelDoc2
                    Dim swComp                  As SldWorks.Component2
                    Dim swConf                  As SldWorks.Configuration
                    Set swModel = swApp.ActiveDoc
                    Set swComp = swSelMgr.GetSelectedObject5(1)
                    Set swConf = swComp.GetModelDoc.GetConfigurationByName(swComp.ReferencedConfiguration)
                    Debug.Print swConf.AlternateName
                    Charles Robin
                    Thanks a lot!
                    I miss ".GetModelDoc."
                    Here the code VBA for all config of all components in an assembly:
                    Sub Main()
                    Debug.Print "_____________________________________________________________________ "
                        Dim swConfigMgr            As SldWorks.ConfigurationManager
                        Dim swConfig                As SldWorks.Configuration
                        Dim swRootComp              As SldWorks.Component2
                        Dim Children                As Variant
                        Dim swChild                As SldWorks.Component2
                        Dim ChildCount              As Integer
                        Dim OldName                As String
                        Dim ViewOldName As String
                        Dim NewName                As String
                        Dim textebox1 As String
                        Dim bOldSetting            As Boolean
                        Dim bRet                    As Boolean
                        Dim i                      As Long
                        Dim III                      As String
                        Dim sPathName                  As String
                        Set swConfigMgr = swModel.ConfigurationManager
                        Set swConfig = swConfigMgr.ActiveConfiguration
                        If swModel Is Nothing Then
                        MsgBox ("Pas de document ouvert")
                        Else
                            If swModel.GetType <> 2 Then
                                MsgBox ("Il ne s'agît pas d'un assemblage")
                                Exit Sub
                            Else
                        Set swRootComp = swConfig.GetRootComponent
                        bOldSetting = swApp.GetUserPreferenceToggle(swExtRefUpdateCompNames)
                        swApp.SetUserPreferenceToggle swExtRefUpdateCompNames, False
                        Children = swRootComp.GetChildren
                        ChildCount = UBound(Children)
                        For i = 0 To ChildCount
                        III = i
                            Set swChild = Children(i)
                            sPathName = swChild.GetPathName
                            sPathName = Mid(sPathName, InStrRev(sPathName, "\") + 1)
                            sPathName = Left(sPathName, Len(sPathName) - 7)
                            Debug.Print "  "
                            Debug.Print "COMPONENENT NAME  =      " + sPathName
                            bRet = swChild.Select2(False, 0)
                            change_alternatename swChild, sPathName
                        Next i
                    Sub change_alternatename(swChild As SldWorks.Component2, sPathName As String)
                        Dim params                  As Variant
                        Dim vName                  As Variant
                        Dim Name                    As String
                        Dim thisConfig              As Configuration
                        params = swChild.GetModelDoc.GetConfigurationNames
                        For Each vName In params
                        Name = vName
                        Set thisConfig = swChild.GetModelDoc.GetConfigurationByName(Name)
                        Debug.Print "Congig Name      =        " + Name
                        Debug.Print "Old AlternateName =          " + thisConfig.AlternateName
                        thisConfig.AlternateName = sPathName
                        Debug.Print "NeW AlternateName =          " + thisConfig.AlternateName
                        thisConfig.BOMPartNoSource = swBOMPartNumber_UserSpecified
                        thisConfig.UseAlternateNameInBOM = False
                    Next vName
