Thanks in advance for your help.
I am importing vendor drawings in DWG format into a SolidWorks drawing file. I am importing from several different DWG files. Each file will import into an individual drawing such that I have Solidworks drawings A, B and C with DWG files a, b and c imported with all content (borders, blocks, drawings, dimensions, comments, etc.). I can save each of these without issue. I need to combine A, B and C SolidWorks drawings into a single drawing D containing all the DWG files. So I start a new drawing and call it D, save it to network. I copy the relevant sheets from A and paste into D, file saves fine. Do the same for B into D, saves fine. Go through the same process with the sheets from C, copy into D, attempt to save and I get the classic "An unknown error occurred while accessing..." I assume the issue is somewhere in the C file, something wrong with the importing maybe. But it imports to its own file just fine.
Also, I instead of copying sheets I attempt to import the DWG file directly into drawing D, it comes through with the model views only - no dimensions, blocks, comments, nothing. If I go the other way and copy sheets from the other files into the C (bad) file, I get the same error. so it seems like there is some compatibility issue happening when the various sheets meet......................THOUGHTS?
