Detached Drawing not showing correct edge colors
Question asked by Tai Wei Yang on Feb 11, 2015
Hi all,
I tried to use detached drawing to quicken the loading times of solidworks.
However, i came across this problem where the color of the edges follows the part instead of the assembly when i enable use model color for HLR/HLV is drawing.
The following is my original colors:
        Correct Edges color as required
However, when i save as detached drawings, it becomes like this:
                                                          wrong color when saved as detached drawing
As you can see, i only want to keep the color of the edges gray and black. I have also noticed that the detached drawing is colored correctly when i use shaded with edges mode.
                                           Shaded with edges is colored correctly
I am currently using solidworks 2014.
Note: I do not have the option to save as edrawing file as i have to constantly update a table in the drawing.
Thanks in advance.
Regards,
Tai
