4 Replies Latest reply on Feb 17, 2015 6:39 AM by Mario Zahren
    How to change Font for each text in drawings using API?
    Mario Zahren
      I want to Change all the text in the drawing e.g.
      Annotations
      Dimensions
      Tables
      Sketches
      Any ideas?
      Thanks in advance
      Cheers
      Mario
        • Re: How to change Font for each text in drawings using API?
          Santosh Pawar
          SetTextFormat Method (IAnnotation)
          2014 SOLIDWORKS API Help - Change Text Format Example (VBA)
          you can iterate over all annotations using GetFirstAnnotation2 and GetNext3
              Mario Zahren
              I´m sorry. I've been trying lots of code but nothing will work. The code insists on a marked text.
              How can I use GetFirstAnnotation2 and GetNext3 in thise case?
              Please excuse my lack of knowledge in coding. I´m a beginner.
              Mario
                  Santosh Pawar
                  Try this,
                      Dim swApp                       As SldWorks.SldWorks
                      Dim swModel                     As SldWorks.ModelDoc2
                      Dim swSelMgr                    As SldWorks.SelectionMgr
                      Dim swAnnObj                    As Object
                      Dim swAnn                       As SldWorks.Annotation
                      Dim swTextFormat                As SldWorks.TextFormat
                      Dim i                           As Long
                      Dim bRet                        As Boolean
                      Dim swDraw As DrawingDoc
                      Set swModel = swApp.ActiveDoc
                  Set swDraw = swModel
                      Set swView = swDraw.GetFirstView
                      Do While Not Nothing Is swView
                          Set swAnn = swView.GetFirstAnnotation3
                          Do While Not Nothing Is swAnn
                              ProcessAnnotation swApp, swAnn
                              Set swAnn = swAnn.GetNext3
                          Loop
                          Set swView = swView.GetNextView
                      Loop
                  Sub ProcessAnnotation(swApp As SldWorks.SldWorks, swAnn As SldWorks.Annotation)
                  Do While Not swAnn Is Nothing
                      ' Get text format information
                      Debug.Print "  " & swAnn.GetName & " <" & swAnn.GetType & ">"
                      For i = 0 To swAnn.GetTextFormatCount - 1
                          Set swTextFormat = swAnn.GetTextFormat(i)
                          ' Change text to be 10mm high, bold, italic, and Comic Sans MS font face
                          swTextFormat.CharHeight = 0.01
                          swTextFormat.Bold = True
                          swTextFormat.Italic = True
                          swTextFormat.TypeFaceName = "Comic Sans MS"
                          bRet = swAnn.SetTextFormat(i, False, swTextFormat): Debug.Assert bRet
                      Next
                      Loop
