When I open a new file in solidworks, I see the toolbar on top, but I do not see the modeling tree or the actual screen, it is just black. Any help would be much appreciated.
Kindly let us know if this problem occurs with part template only or it occurs with new Assembly template also.
It may be an issue with your graphic card driver.
To check the same :
Open your SolidWorks.
Go to tools>Options>Performance.
See the option "Use Open GL" is checked or not.
If it unchecked , check the option.
Try opening your part template.
I hope it helps.
Thanks & Regards,
R.Vignesh
