hi, is anyone knows what is the syntax for cut list item name? Thx.
I need to detail a connection frame that is being fabricated on to an existing fabrication.
The existing fabrication is an assembly. The new frame that envelopes the existing fabrication is a weldment.
Typically I would do the second fabrication as an assembly and 'promote' the parts within the BOM options. To make the parts appear in the next assembly level ups' BOM.
I believe 'detailed cut lists' are the weldment equivalent?
I use the 'cut list item name' as the item description in my weldment cutlists. 'Cut list item name' is the name of body folders in the weldment.
I can get it to pull through the length of weldment parts but not the 'cut list item name'. How do I go about this?
Thank you all in advance for your time and help!
Hey Deepak,
I'm trying to get that "cut list item name" property to automatically populate in the title block of a weldment drawing as the part number of each individual body drawing on additional sheets. I believe that this will require me saving a separate sheet format for additional sheets. I also want to link the quantity of each item in the weldment to the title block as well. Do you know of any possible way to do this?
Tim, yes you would need to set up another sheet format. And for quantity you can add a property in the cut list and link to that. But you'll have to fill that property in model manually OR use some macro to populate the property.
Use $PRPWLD:"Property Name here" OR here's another way : Re: show description of cut list in drawing
