I have an assembly that I would like to mirror, then save the mirror assembly as a master assembly so any changes I make to the first will be mirrored in the second. I am also having trouble mirroring the components a certain distance apart. I go through mirror components wizard in the linear components menu, but I cannot figure out how to do it so the parts lie a specified distance from each other. Thanks in advance for your help!
Hinton
Do you mean you want move the mirrored components? If yes then create a new plane and use that as mirror plane. You'll have to keep the plane distance half of the required distance.
