I'm trying to create a mold with 2 cavities.
Here are the steps I took:
1. I started from a single body part
2. I made a copy of the body
3. I added the parting line, the shut-off surfaces and the parting surfaces.
4. The TOOLING SPLIT tool refuses to create the core and cavity.
I attached the part (Solidworks 2014)
Enrico Migliore
P.S.
At the end of the mold design I will post it to the forum
You will need to do the tooling split to a single part.
Then you can use the body Move/Copy feature to create a copy with a rotation point defined.
Then combine the bodies to create a single core block and single cavity block.
If this a real world mold, I would recommend an increasing the draft on the walls to a minimum of 3°. 5° would be much better.
