EPDM Convert SWAdd-in question
Question asked by Rupesh Gandupalli on Feb 5, 2015
I am new to EPDM, just wanted to change the filename variable for each configurations based on the configuration specific properties. I don't know how to change the macro in "Advanced macro options".
I copied the macro code to Visual Studio 2010 a temp file and add the code in multiple configs loop, pasted back the code in the add-in and it fails..
I am pasting the changed code here, and you can find for this below change block in the pasted code..
     '------------Changed for different configurations
                    VarValue = GetVariableValue(docFileName, "Number", vConfNames(i))
                    VarValue1 = GetVariableValue(docFileName, "Revision", vConfNames(i))
                    convFileName = "<VaultPath>"
                    convFileName = convFileName & "\Configuration Management\CAD\" & VarValue & "-" & VarValue1 & ext
How can debug or test this change...appreciate your help..
'Enterprise PDM 2014 - Default Convert Task Script
'SPR Updates:
'2014 PR1 - SPRs 682792, 538578, 651998
Dim swApp As Object
Dim swDrawing As SldWorks.DrawingDoc
Dim swAssembly As SldWorks.AssemblyDoc
Dim swExtension As SldWorks.ModelDocExtension
Dim swConfMgr As SldWorks.ConfigurationManager
Dim swPDFExport As SldWorks.ExportPdfData
Dim swDocSpecification As SldWorks.DocumentSpecification
Dim FileSystemObj As Object
Dim errors As Long
Dim warnings As Long
Dim vault As Object
#If VBA7 Then
    Private Declare PtrSafe Function SHCreateDirectoryEx Lib "shell32" Alias "SHCreateDirectoryExA" (ByVal hwnd As Long, ByVal pszPath As String, ByVal psa As Any) As Long
    Private Declare PtrSafe Function PathIsRelative Lib "shlwapi.dll" Alias "PathIsRelativeA" (ByVal pszPath As String) As Long
#Else
Private Declare Function SHCreateDirectoryEx Lib "shell32" Alias "SHCreateDirectoryExA" (ByVal hwnd As Long, ByVal pszPath As String, ByVal psa As Any) As Long
Private Declare Function PathIsRelative Lib "shlwapi.dll" Alias "PathIsRelativeA" (ByVal pszPath As String) As Long
#End If
Private Sub LoginToVault()
    On Error GoTo ErrHand
    Dim strTempVaultName As String
    Dim strVaultName As String
    strTempVaultName = "<VaultPath>"
    i = Len(strTempVaultName)
    j = InStrRev(strTempVaultName, "\")
    strVaultName = Right(strTempVaultName, i - j)
    vault = CreateObject("ConisioLib.EdmVault")
    vault.LoginAuto(strVaultName, 0)
    Exit Sub
ErrHand:
    If Not vault Is Nothing Then
        Dim errname As String
        Dim errdesc As String
        vault.GetErrorString(Err.Number, errname, errdesc)
        Log("LoginToVault error" & vbCrLf & errname & vbCrLf & errdesc)
    Else
        Log("Error creating file vault interface.")
Private Function GetVariableValue(ByVal FilePath, ByVal VariableName, ByVal Configuration)
    Dim File As Object
    'Get the interface of the file (and its parent folder)
    Dim Folder As Object
    File = vault.GetFileFromPath(FilePath, Folder)
    'Obtain the variable interface
    Dim pEnumVar As Object
    pEnumVar = File.GetEnumeratorVariable
    Dim Value As Object
    If pEnumVar.GetVar(VariableName, Configuration, Value) Then
        GetVariableValue = Value
    Else
        GetVariableValue = ""
    Exit Function
ErrHand:
    Dim ename As String
    Dim edesc As String
    vault.GetErrorString(Err.Number, ename, edesc)
    Log("GetvariableValue error" & vbCrLf & ename & vbCrLf & errdesc)
End Function
Private Function CompareLocalvsLatestVersion(ByVal filePath As String)
    Dim File As Object
    If File Is Nothing Then
        Exit Function 'No file cached
    Dim versionNo As Long
    Dim versionLatest As Long
    versionLatest = File.CurrentVersion
    versionNo = File.GetLocalVersionNo(filePath) 'Obtain the local version
    If Not (versionLatest = versionNo) Then
        Log("The version of the locally cached file " & filePath & " is " & CStr(versionNo) & " while the latest version is " & CStr(versionLatest) & ".")
        Success = False
    Exit Function
ErrHand:
    Dim ename As String
    Dim edesc As String
End Function
Function PathAppend(ByVal path, ByVal more) As String
    If Not Right(path, 1) = "\" Then
        path = path & "\"
    If Left(more, 1) = "\" Then
        more = Mid(more, 2)
    PathAppend = path & more
End Function
Sub Log(ByVal message)
    Dim errorLogFolder As String
    Dim errorLogPath As String
    ' Determine error log output path
    errorLogFolder = "[ErrorLogPath]"
    ' Trim \ from the start
    If Left(errorLogFolder, 1) = "\" Then
        errorLogFolder = Mid(errorLogFolder, 2)
    ' Build full root
    If PathIsRelative(errorLogFolder) = 1 Then
        errorLogPath = PathAppend("<VaultPath>", errorLogFolder)
    Else
        errorLogPath = errorLogFolder
    ' Create directory if not exists
    SHCreateDirectoryEx ByVal 0&, errorLogPath, ByVal 0&
    errorLogPath = PathAppend(errorLogPath, "<TaskInstanceGuid>.log")
    ' Write error to output file
    Open errorLogPath For Append As #1
    Print #1, message
    Close #1
Sub CreatePath(ByVal path)
    If SHCreateDirectoryEx(ByVal 0&, path, ByVal 0&) = 0 Then
        ' Create temp file
        Open path & "~$holder" For Append As #1
        Close #1
Sub KillHolder(ByVal path)
    On Error GoTo Ignore
    If FileSystemObj.FileExists(path & "~$holder") Then
        Kill(path & "~$holder")
Ignore:
Function GetExtension(ByVal docType, ByVal fileFormat)
    first = InStr(1, fileFormat, "(")
    last = InStr(first, fileFormat, ")")
    extensions = Mid(fileFormat, first + 1, last - first - 1)
    If InStr(1, extensions, ";") > 0 Then
        Dim all As Object
        all = Split(extensions, ";")
        If UBound(all) >= docType - 1 Then
            ext = all(docType - 1)
        Else
            ext = "*." ' Nothing
    Else
        ext = extensions
    GetExtension = Mid(Trim(ext), 2)
End Function
Sub SetConversionOptions(ByVal ext)
    ' PDF options
    If LCase(ext) = ".pdf" Then
        swApp.SetUserPreferenceToggle(swPDFExportInColor, [PdfInColor])
        swApp.SetUserPreferenceToggle(swPDFExportEmbedFonts, [PdfEmbedFonts])
        swApp.SetUserPreferenceToggle(swPDFExportHighQuality, [PdfHighQuality])
        swApp.SetUserPreferenceToggle(swPDFExportPrintHeaderFooter, [PdfPrintHeaderFooter])
        swApp.SetUserPreferenceToggle(swPDFExportUseCurrentPrintLineWeights, [PdfUsePrinterLineWeights])
        ' IGES
    ElseIf LCase(ext) = ".igs" Then
        swApp.SetUserPreferenceToggle(swIGESExportSolidAndSurface, [IgesExportSolidSurface])
        swApp.SetUserPreferenceIntegerValue(swIGESRepresentation, [IgesRepresentation])
        swApp.SetUserPreferenceToggle(swIGESExportAsWireframe, [IgesExportWireframe])
        swApp.SetUserPreferenceIntegerValue(swIGESCurveRepresentation, [IgesCurveRepresentation])
        swApp.SetUserPreferenceIntegerValue(swIGESSystem, [IgesSystem])
        swApp.SetUserPreferenceToggle(swIGESExportFreeCurves, [IgesExportFreeCurves])
        swApp.SetUserPreferenceToggle(swIGESExportSketchEntities, [IgesExportSketchEntities])
        swApp.SetUserPreferenceToggle(swIGESHighTrimCurveAccuracy, [IgesHighCurveAccuracy])
        swApp.SetUserPreferenceToggle(swIGESComponentsIntoOneFile, [IgesComponentsIntoOneFile])
        swApp.SetUserPreferenceToggle(swIGESFlattenAssemHierarchy, [IgesFlattenAssemblyHierarchy])
        ' ACIS
    ElseIf LCase(ext) = ".sat" Then
        swApp.SetUserPreferenceIntegerValue(swAcisOutputGeometryPreference, [AcisGeometry])
        swApp.SetUserPreferenceIntegerValue(swOutputVersion, [AcisVersion])
        swApp.SetUserPreferenceIntegerValue(swAcisOutputUnits, [AcisOutputAsUnit])
        ' STEP
    ElseIf LCase(ext) = ".step" Then
        swApp.SetUserPreferenceIntegerValue(swAcisOutputGeometryPreference, [StepGeometry])
        swApp.SetUserPreferenceIntegerValue(swStepAP, [StepVersion])
        ' Parasolid
    ElseIf LCase(ext) = ".x_t" Or LCase(ext) = ".x_b" Then
        swApp.SetUserPreferenceIntegerValue(swParasolidOutputVersion, [ParasolidVersion])
        swApp.SetUserPreferenceToggle(swXTAssemSaveFormat, [ParasolidFlattenHierarchy])
        ' VRML
    ElseIf LCase(ext) = ".wrl" Then
        swApp.SetUserPreferenceIntegerValue(swExportVrmlUnits, [VrmlOutputAsUnit])
        swApp.SetUserPreferenceToggle(swExportVrmlAllComponentsInSingleFile, [VrmlSaveAssemblyAsOneFile])
        ' STL
    ElseIf LCase(ext) = ".stl" Then
        swApp.SetUserPreferenceToggle(swSTLBinaryFormat, [StlOutputAs])
        swApp.SetUserPreferenceIntegerValue(swExportStlUnits, [StlOutputAsUnit])
        swApp.SetUserPreferenceIntegerValue(swSTLQuality, [StlQuality])
        swApp.SetUserPreferenceToggle(swSTLDontTranslateToPositive, [StlDontTranslatePositive])
        swApp.SetUserPreferenceToggle(swSTLComponentsIntoOneFile, [StlComponentsIntoOneFile])
        swApp.SetUserPreferenceToggle(swSTLCheckForInterference, [StlCheckForInterferences])
        ' TIF or PSD
    ElseIf LCase(ext) = ".tif" Or LCase(ext) = ".psd" Then
        swApp.SetUserPreferenceIntegerValue(swTiffImageType, [TifImageType])
        swApp.SetUserPreferenceIntegerValue(swTiffCompressionScheme, [TifCompressionScheme])
        ' eDrawings
    ElseIf LCase(ext) = ".eprt" Or LCase(ext) = ".easm" Or LCase(ext) = ".edrw" Then
        swApp.SetUserPreferenceToggle(swEDrawingsOkayToMeasure, [EdrwOkayToMeasure])
        swApp.SetUserPreferenceToggle(swEDrawingsExportSTLOkay, [EdrwAllowExportOfSTL])
        swApp.SetUserPreferenceToggle(swEDrawingsSaveShadedDataInDrawings, [EdrwSaveShadedData])
        swApp.SetUserPreferenceToggle(swEDrawingsSaveBOM, [EdrwSaveBOM])
        swApp.SetUserPreferenceToggle(swEDrawingsSaveAnimationOkay, [EdrwSaveMotionStudies])
        swApp.SetUserPreferenceToggle(swEDrawingsSaveAnimationToAllConfigs, [EdrwSaveMotionStudiesToAllConfs])
        swApp.SetUserPreferenceToggle(swEDrawingsSaveAnimationRecalculate, [EdrwRecalcMotionStudies])
Function GetFullFileName(ByVal convFileName, ByVal conf, ByVal i, ByVal itemCount)
    ' Configuration name may include backslash. Remove it since otherwise saving will
    ' fail due a missing directory
    conf = Replace(conf, "\", "")
    conf = Replace(conf, "/", "")
    finalFileName = Replace(convFileName, "<Configuration>", conf)
    ' If no configuration
    If finalFileName = convFileName And itemCount > 0 Then
        finalFileName = Left(convFileName, InStrRev(convFileName, ".") - 1) & "_" & i & Mid(convFileName, InStrRev(convFileName, "."))
    ' Remove illegal characters from filename
    finalFileName = Replace(finalFileName, "<", "")
    finalFileName = Replace(finalFileName, ">", "")
    finalFileName = Left(finalFileName, 2) + Replace(finalFileName, ":", "", 3) ' Don't start from begin since drive has :
    finalFileName = Replace(finalFileName, "*", "")
    finalFileName = Replace(finalFileName, "?", "")
    finalFileName = Replace(finalFileName, """", "")
    finalFileName = Replace(finalFileName, "|", "")
    GetFullFileName = finalFileName
End Function
Sub Convert(ByVal docFileName)
    'Get the vault interface
    Call LoginToVault()
    'Get Variable Value
    Dim VarValue
    VarValue = GetVariableValue(docFileName, "Number", "Default")
    Dim VarValue1
    VarValue1 = GetVariableValue(docFileName, "Revision", "Default")
    ' Constants for some SolidWorks error/warning returns that may be encountered during a convert operation.
    Const swerr_InvalidFileExtension = 256   ' the file extension differs from the SW document type.
    Const swerr_SaveAsNotSupported = 4096    ' the options selected for this convert aren't supported, output may be incomplete.
    Const swwarn_MissingOLEObjects = 512     ' the document contains OLE objects and must be opened and converted in SolidWorks.
    ' Determine type of SolidWorks file based on file extension
    If LCase(Right(docFileName, 7)) = ".sldprt" Or LCase(Right(docFileName, 4)) = ".prt" Then
        docType = swDocPART
    ElseIf LCase(Right(docFileName, 7)) = ".sldasm" Or LCase(Right(docFileName, 4)) = ".asm" Then
        docType = swDocASSEMBLY
    ElseIf LCase(Right(docFileName, 7)) = ".slddrw" Or LCase(Right(docFileName, 4)) = ".drw" Then
        docType = swDocDRAWING
    Else
        docType = swDocNONE
        If bIsSupportedExtension(Mid(docFileName, InStrRev(docFileName, ".") + 1)) = False Then
            Log("The file extension '" & Mid(docFileName, InStrRev(docFileName, ".") + 1) & "' is not supported.")
            Exit Sub
    ' Open document
    If docType = swDocNONE Then
        swModel = swApp.LoadFile4(docFileName, "", Nothing, errors)
        docType = swModel.GetType
    Else
        swDocSpecification = swApp.GetOpenDocSpec(docFileName)
        swDocSpecification.DocumentType = docType
        swDocSpecification.ReadOnly = True
        swDocSpecification.Silent = True
        swDocSpecification.ConfigurationName = ""
        swDocSpecification.DisplayState = ""
        swDocSpecification.IgnoreHiddenComponents = True 'SPR 682792, 538578, 651998
        swModel = swApp.OpenDoc7(swDocSpecification)
        errors = swDocSpecification.Error
        ' Set swModel = swApp.OpenDoc6(docFileName, docType, swOpenDocOptions_Silent Or swOpenDocOptions_ReadOnly, "", errors, warnings)
    If errors = swFutureVersion Then
        Log("Document '" & docFileName & "' is future version.")
        Exit Sub
    ' Load failed?
    If swModel Is Nothing Then
        Log("Method call ModelDoc2::OpenDoc7 for document '" & docFileName & "' failed. Error code " & errors & " returned.")
        Exit Sub
    If Val(Left(swApp.RevisionNumber, 2)) >= 18 Then
        swApp.Frame.KeepInVisible = True
    swApp.ActivateDoc2(docFileName, True, errors)
    modelPath = swModel.GetPathName()
    If modelPath = "" Then
        modelPath = docFileName
    modelFileName = Mid(modelPath, InStrRev(modelPath, "\") + 1)
    modelFileName = Left(modelFileName, InStrRev(modelFileName, ".") - 1)
    modelExtension = Mid(modelPath, InStrRev(modelPath, ".") + 1)
    ' Build destination filenames
    convFileName = "[OutputPath]"
    Dim convFileName2 As String
    convFileName2 = "[OutputPath2]"
    Dim convFilePath2 As String
    Dim convFileNameTemp2 As String
    Dim bSecondOutput As Boolean
    bSecondOutput = False
    If (Len(convFileName2) > 0) Then
        bSecondOutput = True
    ext = GetExtension(docType, "[FileFormat]")
    convFileName = Replace(convFileName, "<Filename>", modelFileName)
    convFileName = Replace(convFileName, "<Extension>", modelExtension)
    convFileName = Replace(convFileName, "<VariableValue>", VarValue)
    convFileName = Replace(convFileName, "<VariableValue1>", VarValue1)
    convFilePath = Left(convFileName, InStrRev(convFileName, "\"))
    CreatePath(convFilePath)
    convFileName = convFileName & ext
    If bSecondOutput = True Then
        convFileName2 = Replace(convFileName2, "<Filename>", modelFileName)
        convFileName2 = Replace(convFileName2, "<Extension>", modelExtension)
        convFilePath2 = Left(convFileName2, InStrRev(convFileName2, "\"))
        CreatePath(convFilePath2)
        convFileName2 = convFileName2 & ext
    ' Set conversion options
    SetConversionOptions(ext)
    swExtension = swModel.Extension
    If docType = swDocDRAWING Then
        Dim vSheetNames As Object
        swDrawing = swModel
        ' All sheets?
        If ([OutputSheets] And 2) = 2 Then
            vSheetNames = swDrawing.GetSheetNames
            ' Last active sheet?
        ElseIf ([OutputSheets] And 4) = 4 Then
            ReDim vSheetNames(0 to 0) As Variant
            vSheetNames(0) = swDrawing.GetCurrentSheet.GetName()
            ' Named sheet
        ElseIf ([OutputSheets] And 8) = 8 Then
            Dim vSheetNamesTemp As Object
            vSheetNamesTemp = swDrawing.GetSheetNames
            removed = 0
            For i = 0 To UBound(vSheetNamesTemp)
                vSheetNamesTemp(i - removed) = vSheetNamesTemp(i)
                sheetName = vSheetNamesTemp(i)
                If Not sheetName Like "[NamedSheet]" Then
                    removed = removed + 1
            Next i
            If (UBound(vSheetNamesTemp) - removed) >= 0 Then
                ReDim Preserve vSheetNamesTemp(0 To (UBound(vSheetNamesTemp) - removed))
                vSheetNames = vSheetNamesTemp
        If Not IsEmpty(vSheetNames) Then
            ' Save sheets one per file
            If ([FileSheets] And 4) = 4 Then
                For i = 0 To UBound(vSheetNames)
                    Dim varSheetName As Object
                    swDrawing.ActivateSheet(vSheetNames(i))
                    convFileNameTemp = GetFullFileName(convFileName, vSheetNames(i), i, UBound(vSheetNames))
                        swPDFExport = swApp.GetExportFileData(1)
                        varSheetName = vSheetNames(i)
                        swPDFExport.SetSheets(swExportData_ExportSpecifiedSheets, varSheetName)
                    ElseIf LCase(ext) = ".edrw" Then
                        swApp.SetUserPreferenceIntegerValue(swEdrawingsSaveAsSelectionOption, swEdrawingSaveActive)
                    ' Convert the document
                    Success = swExtension.SaveAs(convFileNameTemp, swSaveAsCurrentVersion, swSaveAsOptions_Silent, swPDFExport, errors, warnings)
                    CompareLocalvsLatestVersion(docFileName)
                    ' Save failed?
                    If Success = False Then
                        If errors = swerr_InvalidFileExtension Then
                            Log("The file '" & docFileName & "' and sheet '" & vSheetNames(i) & "' can't be converted to the file extension '" & ext & "'.")
                        Else
                            Log("Method call ModelDocExtension::SaveAs for document '" & convFileNameTemp & "' and sheet '" & vSheetNames(i) & "' failed. Error code " & errors & " returned.")
                            If (((errors And swerr_SaveAsNotSupported) <> 0) And ((warnings And swwarn_MissingOLEObjects) <> 0)) Then
                                Log("This document contains OLE objects. Such objects can't be converted outside of SolidWorks. Please open the document and perform the conversion from SolidWorks.")
                        convFileNameTemp2 = GetFullFileName(convFileName2, vSheetNames(i), i, UBound(vSheetNames))
                        Success = swExtension.SaveAs(convFileNameTemp2, swSaveAsCurrentVersion, swSaveAsOptions_Silent, swPDFExport, errors, warnings)
                        ' Save failed?
                            Else
                                Log("Method call ModelDocExtension::SaveAs for document '" & convFileNameTemp2 & "' and sheet '" & vSheetNames(i) & "' failed. Error code " & errors & " returned.")
                Next i
                ' Save PDF sheets to one file
            ElseIf ([FileSheets] And 2) = 2 Then
                    swPDFExport = swApp.GetExportFileData(swExportPdfData)
                    swPDFExport.SetSheets(swExportData_ExportSpecifiedSheets, vSheetNames)
                    If ([OutputSheets] And 2) = 2 Then ' All sheets?
                        swApp.SetUserPreferenceIntegerValue(swEdrawingsSaveAsSelectionOption, swEdrawingSaveAll)
                    ElseIf ([OutputSheets] And 4) = 4 Then ' Last active sheet?
                    ElseIf ([OutputSheets] And 8) = 8 Then ' Named sheet
                        swApp.SetUserPreferenceIntegerValue(swEdrawingsSaveAsSelectionOption, swEdrawingSaveSelected)
                        selectedSheets = Join(vSheetNames, vbLf)
                        swApp.SetUserPreferenceStringListValue(swEmodelSelectionList, Trim(selectedSheets))
                convFileNameTemp = GetFullFileName(convFileName, "All", 0, 0)
                ' Save failed?
                    Log("Method call ModelDocExtension::SaveAs for document '" & convFileNameTemp & "' failed. Error code " & errors & " returned.")
                    convFileNameTemp2 = GetFullFileName(convFileName2, "All", 0, 0)
                    ' Save failed?
                        Log("Method call ModelDocExtension::SaveAs for document '" & convFileNameTemp2 & "' failed. Error code " & errors & " returned.")
        Else
            Log("Document '" & docFileName & "' didn't contain any sheets named '[NamedSheet]'.")
    Else
        Dim vConfNames As Object
        swConfMgr = swModel.ConfigurationManager
        ' All configurations?
        If ([OutputConfs] And 2) = 2 Then
            vConfNames = swModel.GetConfigurationNames
            ' Last active conf?
        ElseIf ([OutputConfs] And 4) = 4 Then
            ReDim vConfNames(0 to 0) As Variant
            vConfNames(0) = swConfMgr.ActiveConfiguration.Name
            ' Named confs
        ElseIf ([OutputConfs] And 8) = 8 Then
            Dim vConfNamesTemp As Object
            vConfNamesTemp = swModel.GetConfigurationNames
            removed = 0
            For i = 0 To UBound(vConfNamesTemp)
                vConfNamesTemp(i - removed) = vConfNamesTemp(i)
                confName = vConfNamesTemp(i)
                If Not confName Like "[NamedConf]" Then
            Next i
            If (UBound(vConfNamesTemp) - removed) >= 0 Then
                ReDim Preserve vConfNamesTemp(0 To (UBound(vConfNamesTemp) - removed))
                vConfNames = vConfNamesTemp
        If Not IsEmpty(vConfNames) Then
            If ([FileConfs] And 4) = 4 Then
                ' Save configurations
                For i = 0 To UBound(vConfNames)
                    convFileNameTemp = GetFullFileName(convFileName, vConfNames(i), i, UBound(vConfNames))
                    Success = swExtension.SaveAs(convFileNameTemp, swSaveAsCurrentVersion, swSaveAsOptions_Silent, Nothing, errors, warnings)
                    ' Save failed?
                            Log("The file '" & docFileName & "' and configuration '" & vConfNames(i) & "' can't be converted to the file extension '" & ext & "'.")
                        Else
                            Log("Method call ModelDocExtension::SaveAs for document '" & convFileNameTemp & "' and configuration '" & vConfNames(i) & "' failed. Error code " & errors & " returned.")
                        convFileNameTemp2 = GetFullFileName(convFileName2, vConfNames(i), i, UBound(vConfNames))
                        Success = swExtension.SaveAs(convFileNameTemp2, swSaveAsCurrentVersion, swSaveAsOptions_Silent, Nothing, errors, warnings)
                        ' Save failed?
                            Else
                                Log("Method call ModelDocExtension::SaveAs for document '" & convFileNameTemp2 & "' and configuration '" & vConfNames(i) & "' failed. Error code " & errors & " returned.")
                                Log("warnings1 = " & warnings)
                Next i
            ElseIf ([FileConfs] And 2) = 2 Then
                If LCase(ext) = ".eprt" Or LCase(ext) = ".easm" Then
                    If ([OutputConfs] And 2) = 2 Then ' All confs?
                    ElseIf ([OutputConfs] And 4) = 4 Then ' Last active conf?
                    ElseIf ([OutputConfs] And 8) = 8 Then ' Named confs
                        selectedConfs = Join(vConfNames, vbLf)
                        swApp.SetUserPreferenceStringListValue(swEmodelSelectionList, Trim(selectedConfs))
                ' Save failed?
                    ' Save failed?
        Else
            Log("Document '" & docFileName & "' didn't contain any configurations named '[NamedConf]'.")
    KillHolder(convFilePath)
    KillHolder(convFilePath2)
    ' Process virtual components
    If docType = swDocASSEMBLY Then
        Dim vComponents As Object
        swAssembly = swModel
        vComponents = swAssembly.GetComponents(True)
        If Not IsEmpty(vComponents) Then
            For i = 0 To UBound(vComponents)
                Dim swComponent As SldWorks.Component2
                swComponent = vComponents(i)
                If swComponent.IsVirtual Then
                    Convert(swComponent.GetPathName())
            Next i
    ' Close document
    swApp.QuitDoc(swModel.GetTitle)
Function bIsSupportedExtension(ByVal oExtension) As Boolean
    oExtension = LCase(oExtension)
    If oExtension = "prt" Then
        bIsSupportedExtension = True
    ElseIf oExtension = "asm" Then
    ElseIf oExtension = "drw" Then
    ElseIf oExtension = "dxf" Then
    ElseIf oExtension = "dwg" Then
    ElseIf oExtension = "psd" Then
    ElseIf oExtension = "ai" Then
    ElseIf oExtension = "lfp" Then
    ElseIf oExtension = "sldlfp" Then
    ElseIf oExtension = "prtdot" Then
    ElseIf oExtension = "asmdot" Then
    ElseIf oExtension = "drwdot" Then
    ElseIf oExtension = "x_t" Then
    ElseIf oExtension = "x_b" Then
    ElseIf oExtension = "xmt_txt" Then
    ElseIf oExtension = "xmt_bin" Then
    ElseIf oExtension = "igs" Then
    ElseIf oExtension = "iges" Then
    ElseIf oExtension = "step" Then
    ElseIf oExtension = "stp" Then
    ElseIf oExtension = "sat" Then
    ElseIf oExtension = "vda" Then
    ElseIf oExtension = "wrl" Then
    ElseIf oExtension = "stl" Then
    ElseIf oExtension = "cgr" Then
    ElseIf oExtension = "xpr" Then
    ElseIf oExtension = "xas" Then
    ElseIf oExtension = "ipt" Then
    ElseIf oExtension = "iam" Then
    ElseIf oExtension = "par" Then
    ElseIf oExtension = "psm" Then
    ElseIf oExtension = "ckd" Then
    ElseIf oExtension = "emn" Then
    ElseIf oExtension = "brd" Then
    ElseIf oExtension = "bdf" Then
    ElseIf oExtension = "idb" Then
    ElseIf oExtension = "3dm" Then
    Else
        bIsSupportedExtension = False
End Function
    On Error GoTo Fail
    FileSystemObj = CreateObject("Scripting.FileSystemObject")
    docFileName = "<Filepath>"
    ' Get SW interface object
    swApp = Application.SldWorks
    swApp.Visible = True    'SPR 682792, 538578, 651998
    Convert(docFileName)
    Exit Sub
Fail:
    Log("Error while converting file '" & docFileName & "': " & vbCrLf & _
        "An unexpected error occurred while executing the generated script. Script syntax error?" & vbCrLf & _
        "Error number: " & Err.Number & vbCrLf & _
        "Error description: '" & Err.Description & "'" & vbCrLf)
