I'm running a flow simulation on proportioner, what i have is a known inlet pressure that I want it to run at, I have a surface goal of force in one direction on a plunger that is in the proportioner that i want to make a known value. What would be unknown is pressure on the outlet and flow. I have been able to solve it for few plunger positions by verying the outlet pressure based until i hit my surface goal that i'm looking for. My question is there a way to say I want my goal to be say 100lbf and have the outlet pressure dependent on metting that surface goal.
The short answer is no. However, you can have the software search the conditions for you to get the flow and pressure that produces the goal you want. Look under solve on the tool bar and select parametric study.
