I'm designing my first mold.
II need to fill or patch a planar surface in order to get a flat parting line.
I attached the design file and a picture.
Thanks in advance for any help,
Enrico Migliore
Enrico Migliore
Enrico,.. add a line at the base of the arc to make a closed boundary and use fill surface..
https://www.dropbox.com/s/iqkmjwq2tcwns7o/PLASTIC-COVER-A4-zxys.zip?dl=0
It's the same procedure as explained in your previous discussion here
Either you can crate a small shut-off surface there or extent the cavity surface to the flat parting surface and then split
There are different ways to accomplish this, depends on the complexity of the part
I had made a small home ventilation system for my college project work. I got inspiration from ventis ventilation system. For moer information visit online at www.ventis.com.au.
